Help on cleaning PC!!
Im thinking of cleaning the interior of my PC...
I searched some websites, saying that I need a can of compressed air. Does this need to bo non-chemical, normal air, or was tat are HFC free, non flammables?
Or if any other easier way of cleaning, feel free to leave a comment.
Cheers.
15 answers Last reply
More about help cleaning
  1. Just compressed air, nothing special. Short bursts or it gets super cold. To be honest, I just use my lungs, it's cheaper.
  2. As Jack says, just any can of compressed air.
    Notes:
    -When cleaning fans, hold the fan blades still and do not let them spin when spraying with air. You could burn out the bearings.
    -When using the can of air, keep the can vertical and do NOT move/shake it. If possible, move the component you are cleaning instead (read, "uninstall components for cleaning").
    Sometimes, it takes more than just a quick blast of air to clean your components. I use an old toothbrush for these situations (Heatsink fins, fan blades).
    Make sure you hit your mothboard slots (RAM/PCI) before re-installing your components.
    Don't forget your power supply. It's probably more dusty than any other component.
    -Wolf sends
  3. Just remove your components and fill your bathtub up with Hydrochloric acid (or the works toilet cleaner, same thing). Immerse them, let them dry re install, you should notice a large performance difference.
  4. The problem is, I cannot find any "normal" can of compressed air...
    It's either a flammable or non-flammable air duster aerosol spray like this:
    http://www.amazon.co.uk/400ml-Compressed-Air-Duster-Cleaner/dp/B002J9N05W/ref=sr_1_15?ie=UTF8&s=officeproduct&qid=1268383094&sr=8-15
    Will this do???
    Will this do???
    That's pretty much exactly what you want. Although I don;t think I would pay £3.29 for a can of air. With luck, you can get it for half that. Check any computer store.
  6. Yeah will do.
  7. Well, it would be interesting to see what would happen if you used this:
    http://www.amazon.co.uk/Star-Duster-Compressed-Flammable-400ml/dp/B000MQ7DZC/ref=pd_sim_office_8
  8. Someone care to explain why you would want it flammable ? Seems odd to me.
  9. What makes it flammable or non-flammable has to do with the accelerant used in the can. Some compressed air cans actually use a fluorocarbon that is a liquid while under pressure, but it becomes a gas once it is released. Hence, the reason why that can becomes cold after prolonged use is because the change from liquid to gas draws heat energy away from the environment (phase-change).
    Personally, I have an air compressor that I use in the garage for air tools and painting that also doubles as my computer dust removal system. I have the added advantage of being able to blow out any dust, even the built-up grime in fans that folks have to take a toothbrush to remove. But canned air works very well for those spot-cleanups also.
    For a thorough cleaning, also look at getting some anhydrous isopropyl alcohol and lint-free microfiber cloth.
  10. To each his own, but I wouldn't suggest using an air compressor to clean electronic parts.
    Air compressors need to be oiled, and that oil gets in the tank. Build the tank to pressure, then open the valve on the bottom once :)
    I don't think flammable would hurt anything, I clean all my components with isopropyl alcohol too and it's flammable as hell.
    Some things spark, Highly flammable liquids/gases + electric sparks = Toast?
    Ofcourse the chances of this happening is probably so low it wouldn't happen.
    I wonder if static charges could ignite these liquids/gases?
  12. Well, ths might sound a bit peculiar, so what I do is:
    1. Take out ram GPU and any pci cards
    2. Get a Hair dryer, set it onto cold (make sure it has a good filter!)
    3. Blow down the mobo
    4. Blow the chips
    5. put them back in.
    I know it might sound a bit on the peculiar side, but it works pretty darn well! :D
  13. Static surely can ignite flammable liquids, but isoproyl alcohol evaporates so fast, it's not really an issue for me. And, if I am letting of ESD near my machine, I hope it lights on fire real pretty like, I'll have an easier time with the insurance company :)
    I have a P-trap in the line that eliminates this as an issue. As I said, I use it for painting as well, and oil, moisture or any fluid in the line does not work well if you are doing any airbrush work. So, I use it without any issues.
  15. Good thing. Most people don't use traps on air compressors, just wanted to try and avoid someone spraying gunk all over their mainboard :)
Homebuilt Systems
