I am buying a new case, and newegg has both the CM 690 II Advanced and CM 690 II basic models for sale. The basic model, accounting for shipping and main in rebates, is $30 cheaper than the advanced model. I was wondering if anyone was aware of any significant differences between the two models that would warrant spending an extra $30 on the advanced.
From what I was able to learn, the advanced model has an external HDD dock, an optional GPU retention bracket for supporting heavy video cards in SLI / XFire, and some bay conversion brackets for turning 5.25" bays into 3.5" ones. I don't mess with HDDs enough to justify spending $30 for the external HDD dock, and couldn't I buy conversion and support brackets if and when I needed them? If anyone knows any other differences I would appreciate the information.
CM 690 II Advanced:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119216&cm_re=cm_690_II-_-11-119-216-_-Product
Cm 690 II Basic:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119215&cm_re=cm_690_II-_-11-119-215-_-Product
Also I was hoping, regardless of which one I choose, to hook up a fan controller to the case. How are the stock fans that come with the CM 690 II and are they able to be hooked up to a fan controller?
Thanks for the help,
-Sean
CM 690 II Advanced:
Cm 690 II Basic:
-Sean
