Hello all.
So i have this fine Corsair H80 in my build, and i makes the rattling noise that some of you probaly know and hate. So i have read a lot on the webs to see what solutions there is, RMA is on ofcourse, but the price for sending it to Corsair is more than a brand new unit, not Corsairs fault, but seems stupid in my eyes.
I've read that people either daisychain cables to lower volts, or make a cable with a diode.
My question is, i use a Fractal Design Define R4, which has a build in regulator that atm runs my 3 case fans, would i be able to just plug the pump power cable into my fan controller which runs my fans on 7v atm, and more important do you guys think it would work? Just don't want to kill anything by testing, since my wallet would kill me in my sleep then.
Hoping there is some bright and helpfull people that can give some inputs.
As an info is temps not the biggest problems, my i5-3550k is only hitting 58 celsius while running Prime95, not oc'ed but don't have the needs for it atm, so that will be when it actually needs it.
Muddy out.
Muddy out.
