Hello everyone,
After some initial setbacks, I recently got my new build up and running.
AMD Phenom II x4 955
ATI 5770
2x2GB Gskill
Antec 300 midtower
Gigabyte 790XTA-UD4
500gb Seagate 7200
650w Antec Earthwatts PSU
I got windows 7 installed and everything seems to be working fine ... except that occasionally for no reason whatsoever (after the PC has been sitting for 10-15 minutes) My monitor will show the 'no video signal, check input cable error'. It doesn't do this all the time after it's been sitting, or even most of the time, but sometimes it will. I am also having problems running Day of Defeat Source, but I am thinking this has something to do with how I transferred the files, not a problem with the actual PC. Is there any tool center I can use to test my video card to make sure it is running the way it is supposed to be? I try to use ATITool_0.26 to run some 3d tests, and it locks my computer up. Same thing happens when I run day of defeat source, it lets me into a server but the monitor goes gray and gets stuck in a sound loop. Any ideas?
Thanks!
ATI 5770
2x2GB Gskill
Antec 300 midtower
Gigabyte 790XTA-UD4
500gb Seagate 7200
Thanks!
