260 GTX Inno3D Freezer X2 Water cooling
Yeah but they are for the normal 260GTX's :)  I need one for the Freezer X2 as it has a differently mounted Heatsink and dual fans. Altho if you could find me one as i have looked that'd be grand mate:)
I do beliece the Freezer X2 on the GTX 260 uses heat pipe fan cooling. While the reserator 1 is a watercooling radiator...
You wouldn't be able to connect the two. You need a video card with a waterblock not heat pipes.
If you do get a card with a waterblock. They will always have G1/4" threads, and you can add your favorite fittings on to hook up to your water cooling loop.
Related ressources
all you got to do is remove the heatsink and fans from your GTX260 then install the GPU waterblock, does the Zalman Reserator 1 water cooling kit come with a full GPU waterblock that cools the VRM's and memory chips or just the GPU?
Heres a video that will show you the basic steps for installing a waterblock on a GPU.
http://www.youtube.com/watch?v=Lo7RWYeBcZk
Are you sure the GPU block that comes with your water cooling kit is compatible with your freezerx2?
please don't buy that!
The pump is rubbish the blocks are very old and im not even sure if the radiator has fans or if its passively cooled!
Look what it says for the GPU block : "This anodized, pure aluminum RAM Water Block is built for high performance cooling, and is compatible with Geforce 7800/7900 and ATI X1800/X1900 in need of VGA RAM cooling. It provides easy installation"
I doubt very much that it will work with your GTX260 and other components, even if it did fit, it would be so bad at cooling you'd be better off with air.
alright thanks, and yeah its fanless but loaded on a non OC standard rig it gets about 50C But im looking at a few solutions. Thanks alot guys of Tomshardware, You've saved me spending money i don't need to again.
On a side note, im using a standard Intel heatsink+fan on my CPU, What would you advise for a P5N-E SlI 775 Q6600. I've been hearing good reviews on the V8.
Omg, What would i need to mount 3 fans onto the RevB cooler and whats the biggest size i can go up too?
Am abit of a noob when it comes to Case modding/Cooling, Have good airflow as everything is tucked behind the Mobo mount.
Thanks again man, Been a great help.
Ask the community
