Hello,
I have 4 3-pin fans in my case but unfortunatly, I only have 3 fan controllers free on my motherboard. Since these are 120mm fans, I am assuming that pluggin them both in the same connector is a bad idea correct? I am therefore looking for a panel controller. I've looked at a few on newegg, and some of them offer some pretty cool features like a tempature display, etc. The problem is, all the reviews say that they don't work or are extremely unreliable... I haven't been able to find a single one with a display that seemed reliable.
My question to you guys is what should I buy? Should I stick with just a plain fan controller?
Any recommendations would be greatly appreciated!
Thanks!
p.s I think this is the right place to post this, but let me know if it isn't.
Thanks!
