Normal CPU Temp? 100% Fan Speed?
Last response: in Systems
Was wondering about the normal temperature for my cpu and wether or not i should be concerned.
Just installed a new Zalman CNPS10X cooler, and so far idle is around 35-40C (with fan speed at 50%) and 28-32C (with fan at 100%)
Under load is around 49-54C with fan on 100%
22cm Fan on front, 22cam fan on side, 12cm exhaust fan.
Processor is Phenom 2 965.
Are these temperatures normal? I'm concerned i didn't apply the thermal paste correctly. (It wouldnt spread, at all)
And is there any way to automate the fan speed? It's pretty noisy at 100%
Thankyou in advance.
Automating fan speed depends on how you have connected it. Zalman heat sinks sometimes come with zalman fan controller (little black box with a knob to play with) I believe you need the 4 pin fan connector plugged directly into the motherboard to control it using software.
Your idle tempratures seem normal but the load temps seem a little too high for that heat sink.
Reseat the heatsink cleaning off the thermal paste and reapplying (only need a thin layer) and test again.
do you know what your room tempreture was? and what case are you using?
Ok, so i reseated the heatsink, and apparantly i completely mucked it up the first time
Sitting at 25-29C idle now and at full load in prime95, top so far is 36C, amazing
thanks a lot :)
Ask the community
