Hey everybody,
I just put together my first water-cooling loop and had some troubles getting the pump to create flow when I began leak testing. I got it to work once I sealed the reservoir (making it a closed loop), however, I'm wondering if the turns I created with my tubing creates too much restriction for the pump and if I should rearrange it.
Here are some pictures of the loop:
BTW the loop order is: Pump > Radiator > CPU Block > Reservoir
Thanks!
Thanks!
