ok as far as i know i put everything together correctly. then because the motherboard has no onboard video i put my nVIDIA 9400gt in it. but for some reason when i power the computer on everything turns on but the computer isnt recognizing the monitor. the monitor just stays the way it is. and i cant get it to show anything. please help, this is my first build
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130265&cm_re=msi_motherboard-_-13-130-265-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130390&cm_re=evga_9400_gt-_-14-130-390-_-Product
just tell me if you need to see the rest of the parts
