I am having trouble testing my pump that is new. It's a Swiftech MCP655 model. This is the first time I have filled it with coolant and it appears like in the image below but with all the tubes and such connected. At this stage, only the pump is connected to an external power supply, NOT the main system as it should be at this point. The only thing I have done to the pump is added a Bitspower "Mod Kit", which required removing the molex pins and putting them back. I followed direction and made sure the wires were in the same 2 slots they were before removal (there is only two a red and black). This pump molex connector is attached to a Molex connector from the external power supply.
The problem is I get no power at all from the pump and I can't hear it running. My external power supply seems to turn on and it's fan does run. However, I noticed the fan was not very loud or spinning very fast, which it may not if no other loads are attached, it's just an old power supply being used to prime the pump. At this point I am not sure what is going on or if there is any power going through that power cable on the power supply. If there is, I do not know why the pump is not working. I don't want to have to drain the new loop and take it apart unless absolutely sure the pump is dead.
If anyone has some thoughts that has used an external power supply to fill their res and power the Swiftech 655 pump let me know what you think may be going on. Not sure what else to try, but I need to know at least if there is full power going to the cable to power the pump before looking at the pump itself.
Thanks for any help.
Here is some other info too that may be the cause but not sure:
Did you do any work on that pump?
I did some work on mine and forgot that the 12v red wire (on pump) needs to be hooked up to the 12v yellow wire on the PSU molex. LOL
Here i was trying to run red wire (on pump) on red (on PSU) and forgot that the red wire on PSU was only 5v.
