Portege 7010CT Problem
Forum Laptops & Notebooks : General Laptops & Notebooks - Portege 7010CT Problem
Archived from groups: comp.sys.laptops (More info?)
> Unit does not post or boot.
> Have tried docked/undocked, plugged in and battery power.
> LEDs indicate power (laptop and docking unit), Battery LED is orange
> (charging), ON light comes on, HD goes on for a while then goes off. No
> activity on the LCD - looks intact though.
> No BIOS screen.
> Is there a hard reset that I can try?
> Am I missing something?
I have tried swapping out ram and HD.
Sponsored Links
"lewdvig" <plongin@hotmail.com> wrote in message
news:Zo9Yc.250547$J06.109025@pd7tw2no...
>> No BIOS screen.
If I press F12 during boot - the bios recovery prompts appears on my screen.
It says press a key, but is not recognizing my key press. I am using the
laptop's keyboard. I know the keyboard works because the system is picking
up the f12 key press. Pressing f12 after the prompt has no effect.
Reply to Anonymous
"Alex Quant" <alexqspam@yahoo.co.uk> wrote in message
news:2pd9c3Fipm5pU1@uni-berlin.de...
> news:u_9Yc.254264$gE.156207@pd7tw3no...
>> >> No
>> >> No BIOS screen.
> screen.
>> picking
> Right - sounds like the laptop works but the BIOS is faulty (a bad flash
> upgrade?). If you have a floppy drive then you might be able to rescue
> this
> Portege. You'll need to download the latest 7010 BIOS file (see link
> below) - I think its a Windows package which will create a boot floppy
> disc
> when launched. Once this disc is created, restart the laptop with the disc
> in the drive and the drive hooked up to the laptop then press F12. With
> fingers and toes crossed, the laptop will recover the BIOS from the disc.
> You'll find the BIOS package here :
> http://209.167.114.38/support/Down [...] /b7010.exe
> .. BIOS upgrade instructions with F12 recovery details :
> http://209.167.114.38/support/Down [...] lation.htm
> .. and other files for the 7010CT here :
> http://209.167.114.38/support/Down [...] 7010en.htm
> Good luck!
> AlexQ
Thanks Alex!
Basically I get to the F12 part (BIOS recovery) and the machine beeps and
tells me to press any button. I pressed a button and nothing happened - its
as if it is not recognizing the key strokes - but it works because I pressed
F12 to get to this screen.
Very strange.
Reply to Anonymous
news:2pdbhbFjmvniU1@uni-berlin.de...
> news:zweYc.254545$J06.58413@pd7tw2no...
>> Thanks Alex!
> its
> pressed
>> Very strange.
> Perhaps if you actually did the BIOS recovery via the floppy drive and
> BIOS
> disc then it will no longer be a mystery?
> Let us know how you get on.
> AlexQ
> ~ Reply To valid ~
You are not understanding. What I am describing above PREVENTS me from doing
the BIOS update by floppy.
Reply to Anonymous
Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > Portege 7010CT Problem
There are 1153 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
