Bootup problems
Hello,
on start up after choosing on the user, xp then just hangs, i have to boot up only in safe mode, what can i use to fix this ?
2 answers Last reply
More about bootup problems
  1. If you can get to safe mode, it's good.
    I'm assuming it happened recent. If so, while in safe mode, type Start>Run>msconfig . There is a button marked System Restore. Click it, choose an earlier date (before this hapened) and let it do the restore, and it will restart. Try getting in your user account now.
    If that's not working, and if it is a corrupt user profile, while you're in safe mode, make a new user account.
    Restart and try to enter the new user.
    If it works, then U may need to copy all your old Desktop and My Documents to this new user
    Old desktop and docs are in C:\Documents and settings\Your_old_user_name
    :hello:
  2. powino20 said:
    Hello,
    Leonard here while ur in safe mode do a disk clean-up & a defrag & error check then resart back in to windows ;)
Configuration Safe Mode Boot Windows XP
