Help me choose, need new card!
Hi, I'm currently in the market for a new gfx card and I'm a bit torn between two brands with slightly different clock speeds
these are the two cards I'm interested in:
Gigabyte Radeon HD7870 2048MB OC
or
MSI Radeon HD7870 2048MB TWIN FROZR
https://www.inet.se/jamfor?compare=5409436&compare=5409...
If you chooses one brand over the other please motivate why you would do so, like if you have had better exp. with one over the other.
and please I dont want to spend more money to get the 7950 as I'm sticking to a budget
Thanks in advance
More about : choose card
or
Thanks in advance
btw My system specs are
i5 3570k (stock atm)
ASRock Z77 Pro3
Corsair 800GS
Corsair H70
Corsair 8gb Vengance
1.5 tb mHDD
Graphics card Master
Overclocking Expert
The mHDD, does that mean it's designed for mobiles (laptops)? Is it 2.5" or 3.5"?
I'm just asking because that could be seriously slowing your computer down.
That being said, I'd go for the Gigabyte - it's got an amazing cooler.
Personally, I would prefer the MSI Twin Frozr because a lot of my friends like the Twin Frozr cooler.
I've never really heard a lot about Gigabyte cards.
But what about the XFX Double D 7870? That one looks promising.
You should talk about what games you're planning to play.
Related ressources
was originally planning for a xfx card with dd, but they're out of stock,
and as far as the hdd goes its a "big boi" but not for laptops, (it sat in my old system ,seagate 7200 something I think).
I am currently w8ing for a 2.5 and will prolly go for a SSD down the road. but right now I just want to play games in full HD, like BF3 FC3 and so on, all the heavy hitting games.
my 800GS have 4x 6+2 pins , which is part of the reason I bought it since I plan on going crossfire in the future...but like I said, with which car :S
Still people here have been recomending the GB card and having 50hz more on clockspeed is definately appealing but so is the cooling which in theory would allow fo loads of overclocking with the msi (and its twin frozr)
pit_1209 said:
Go with gigabyte, in this review they compare the gigabyte windforce against msi twin fozr with a hd 7950, the windforce win but is almost the same and the gigabyte one looks cooler.
http://www.hardwarecanucks.com/forum/hardware-canucks-r...
yea saw that the GBt was better on 7950 but I actually compared from 2 different reviews the GBt vs Powercolor PCS+ and the MSI card from another site and appearantly the GBt card has the worst OC abilities, especially in memory.
yet again I thought I was convinced that I would go with the MSI but almost all people advise me to go with GBt so I guess I'm gonna have to go with it
If you wanna go with the MSi go for it, is not like you´re going to regret that desicion, at that level it´s just matter of preferences, those cards are virtually the same, go with the cheaper one.
I respect that decision. I suggested MSI because I'm extremely afraid of handling a GPU and accidentally breaking the cooler, and the Gigabyte cooler looks quite fragile in my hands.
You'll have a blast with those big fans. I don't think the OC is all that bad.
I have msi gtx 680 with twin frost card under full load for hours of gaming will not pass 72 degrees at 1212 oc core. Fans hit 70 percent bit loud in my case but worth the cooling. I know asus has very good cooling. I read the reviews on gigabyte non are a bad choice but most reviews favor twin frost for best cooling. Plus msi afterburner is cool and easy to use. I guess im partial to msi since I own it to be honest but I did my research asus best for oc by a smudge but twin forst always wins in cooling.
