Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Power Supplies, Cases & Mods > Are HP power supplies upgradeable?
Forum CPU & Components : Power Supplies, Cases & Mods Are HP power supplies upgradeable?
Hello,
I just got through with an on-line HP person who told me that HP power supplies are not upgradeable...???? HP rep basically said: :non:
The rep HP rep had no answer when I asked "Why not?" So I asked "is it fused into the case?" Then the rep replied "yes" I asked "are you sure?" ... I asked this becuse it took the rep 20 minutes to find out what the power supply was ... then the person said "you'll void your warrantee" ... Then quickly typed "I hope I've answered your question" and went away ...
That just seems rediculous; that a power supply would be fused into a case. Reason for this thread is that I am looking at an HP Pavilion H-250 however the power supply is apparently crazy low @ 430W. To this computer I want to replace the 5770 with a gtx 470. Why on earth does HP always put such low power supplies into their computers as a rule?
Maybe I should just be happy with the putter the way it's being sold with the 5770:
http://www.newegg.com/Product/Prod [...] 6883147177
Reply to cognitoo
HP Pavilion Elite HPE-170t series
4.2 out of 5 4.2 out of 5 stars (9 reviews)
High-performance PC with Intel Core quad-core i7 and a 2 year warranty for greater piece of mind.
* Genuine Windows 7 Home Premium 64-bit
* Intel(R) Core(TM) i7-860 quad-core processor [2.8GHz, 1MB L2 + 8MB shared L3 cache]
* 6GB DDR3-1333MHz SDRAM [3 DIMMs]
* FREE UPGRADE! 1TB 5400 rpm SATA 3Gb/s hard drive from 640GB
* 512MB NVIDIA GeForce G210 [DVI, HDMI, VGA]
* Norton Internet Security(TM) 2010 - 15 month
* 2-year In-Home limited hardware warranty. This looks like the same machine, this is from the HP web site. The PSU appears to be an atx form factor and you could replace it with a quality brand like Corsair, a 500 watt would do very nicely.
Reply to janxta
250f ... not 'h' but the link was posted above.
the reason i was wanting to use this for an upgrade i thought would be obvious: i7 860, 8gigs ddr3, wireless 802.11n ... for $1200 and the fact that the ibuypower and cyberpower customer reviews are SOOO incredibly Negative on Newegg about both companies! Basically that's all Newegg sells .. and those ZT's [?] and HP's
i just wanted to bump up the video card if possible particularly to a high end nvidia card.
anyone know if this MOBO can support a higher PS or for that matter what make the MOBO is??
Reply to cognitoo
Best answer selected by cognitoo.
------------------------------ i5 750 / MSI P55-GF80 / G.Skill Ripjaw 4GB / 2 x PNY GTX460 SLI / WD 640GB 32mb / XFX 750W BE / Coolermaster 212 plus / Coolermaster 690 II
Reply to cognitoo
Thank you for that answer ... that'a pretty much where I'm headed.
My only fear is that I know Nothing about how to deal with the BIOS on new build. Any good links where I can learn about that?
I have been putting together a 'wish list' of items for a new build at the newegg site for some time .... i just really don't want to fry the MOBO and everything else because I forgot to do something. perhaps i should order the parts and have a local shop assemble it ... or is it really that easy to do?
Reply to cognitoo
This is what I have in the shopping cart at the moment for a build I am considering. I have the gtx 260 core 216 in there for now as I am not entirely convinced I want the gtx 470 ... maybe a 480? in any event I think I would do the build with the 260 and wait a while to upgrade to the 4xx. I would like to keep the price to 1500 max. [?] but that's not entirely in stone just me telling myself that enough is enough and not to go overboard with $$ :non: $$
ZALMAN ZM750-HP 750W Continuous @ 45°C (Maximum Continuous Peak: 850W) ATX12V V2.2 / EPS12V V2.91 SLI Certified CrossFire ...
$129.99
EVGA 896-P3-1257-AR GeForce GTX 260 Core 216 Superclocked Edition 896MB 448-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI ...
$209.99
COOLER MASTER CM690 II Advanced Black Steel body / Plastic + Mesh bezel ATX Mid Tower Computer Case
99.99
COOLER MASTER Intel Core i7 compatible V8 RR-UV8-XBU1-GP 120mm Rifle CPU Cooler
$59.99
EVGA 141-BL-E757-TR LGA 1366 Intel X58 ATX X58 SLI LE Intel Motherboard
$199.99
Intel Core i7-930 Bloomfield 2.8GHz LGA 1366 130W Quad-Core Desktop Processor Model BX80601930
$288.99
OCZ Vertex Series OCZSSD2-1VTX30GXXX 2.5" 30GB SATA II MLC Internal Solid State Drive (SSD)
$106.99
G.SKILL 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory Model F3-12800CL8TU-6GBPI
$184.99
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
$74.99
LITE-ON 24X DVD Writer Black SATA Model iHAS424-98 LightScribe Support
$27.99
Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders
99.99
Rosewill RTK-045 45 Piece Premium Computer Tool Kit
$19.99
Subtotal: $1,503.88
Message edited by cognitoo on 05-20-2010 at 05:19:06 AM
Reply to cognitoo
In answer to your questions:
APPROXIMATE PURCHASE DATE: (in the next 1 - 3 months)
BUDGET RANGE: (800 - 1500) [rebates never come ... from Any company ...]
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: (gaming, surfing, blue ray movies however those drives are finicky w.r.t. drivers and software ... so scratch the blue ray drive )
PARTS NOT REQUIRED: ( do Not need keyboard, mouse, monitor, speakers) **wireless HP keyboard and wireless HP mouse ** 47" LCD HDTV **
PREFERRED WEBSITE(S) FOR PARTS: (newegg.com, or any other place ... I've only looked at newegg)
COUNTRY OF ORIGIN: (US)
PARTS PREFERENCES: by brand or type (Intel , Nvidia)
OVERCLOCKING: No
Maybe SLI : Yes [maybe]
MONITOR RESOLUTION: (1920x1080)
ADDITIONAL COMMENTS: I want it to cun cooler than the surface of the sun ... I want it to run quieter than a freight train ... the bling is not important
Reply to cognitoo
There are 1800 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Case with filters. Recommendations?
By al360ex, 3 hours ago:
Then I'd go with one of these cases. If you choose the HAF 932 Advanced Edition, you...
Best offers
Top experts
