Sign-in / Sign-up
First build for under 600$ - looking for advice
  • Motherboards
  • Build
  • Product
November 8, 2010 12:44:28 AM
This is my first build and i have picked parts listed here and i am wondering if there are any other options i should take a look at.
CPU:
Motherboard:
Hard Drive:
Power Supply:
Case:
DVD Burner:
Memory:
GPU:
MSI 8800GT OC- this is temporary, i plan on using my old card until i can afford a good ATI GPU.
OS:
Windows 7 64 bit
I also plan on adding more memory to this system when i can afford it, adding a fan controller(but i believe that the mobo should let me control fan speed through bios). I don't plan on overclocking too much either.
This computer is going to be mainly used for:
Everyday use
Gaming
More about : build 600 advice
a b V Motherboard
November 8, 2010 1:07:32 AM
Couple thing I'd change :
On the CPU get the 955 instead -- It's the same CPU just one multiple set one value lower, so can be upped in the BIOS easily and will be the same for $15 less
For the HDD I'd instead go with the WD Caviar Blue 500GB for $39 at COMPUSA --- Twice the storage and better performance for same price !
Also on the Memory I'm not familiar with WinTec - but I normally stick with Corsair, G-Skill, OCZ, Crucial so might check to see what they have in the same price range with perhaps a better latency.
November 8, 2010 1:38:34 PM
thanks i appreciate the feedback
