Just got my built running using windows 7 64 bit. Hit asus to grab the lastest updates and I'm still having issues. My guess is the lan driver is not installed correctly preventing the system from using the wireless pci linksys I have installed from working. In device manager the system will not see the card, further more I tried to install the netgear wireless usb draft N stick I have. The drivers install however the system refuses to see it. Under device manager I'm getting 2 ?s for drivers which I suspect are causing the issue. First one, [Property- Hardware Lds] [Value- ACPI\PNP0200 / *PNP0200] The second [Property - Hardware Ids] [value- HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_10438FE&REV_1001]. Any idea where I can get these drivers so I can unlock my networking and get this rig back online.
M3A78 EM
4gig DDR2 800
amd 9850 BE
GtX 470
Linksys pci wireless N nic.
Windows 7 64bit upgrade from vista 64bit.
thanks
M3A78 EM
4gig DDR2 800
amd 9850 BE
GtX 470
thanks
