APPROXIMATE PURCHASE DATE: Looking to buy parts in the next couple days BUDGET RANGE: 400-600
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Photoshop, media, gaming.
PARTS NOT REQUIRED: monitor, keyboard, mouse,
PREFERRED WEBSITE(S) FOR PARTS: newegg.com/tigerdirect.com COUNTRY OF ORIGIN: US
PARTS PREFERENCES: Only preference is AMD phenom 955 be, or i5 really. Seeing as the budget is tight though I could sacrifice a graphics card for integrated, and just not worry about the gaming aspect for now, I would however like to be able to do that at some point and not have to buy a new mobo. That is probably asking a lot, which is why im so flustered by all the choices out there. aside from the processor i dont have brand preference, just something quality/affordable with decent specs.
OVERCLOCKING: Maybe SLI OR CROSSFIRE: no
MONITOR RESOLUTION: not sure
ADDITIONAL COMMENTS: I would really like to be able to build the system off of an i5 or 955 be, just wondering if it can be done within budget.
CPU/mobo combo i was thinking of
ASUS M4A89GTD PRO AM3 AMD 890GX SATA 6Gb/s HDMI ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131633
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz 4 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103674
combo costs=$300
or
Asus P7P55D LE Motherboard - Intel P55, Socket LGA1156, CrossFire, 2133MHz, DDR3
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5210440&CatId=4725
Intel Core i5 750 BX80605I5750 Processor
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4959973&CatId=4731
combo costs=$314
(would however need a video card with the intel setup)(willing to get a cheap one for the time being though)
What should I get? Remember im not set on anything at this point. i5/955 are just what im hoping to squeeze into the budget.
combo costs=$300
or
combo costs=$314
