ok hang on!.. this is gonne be really confusing.. so i really hope someone can fix it.. or atleast me an answer why it doesnt work
ok so i got 2 monitors.. both are VGA..
i got 2 inputs into my video card.. DVI and VGA.. bought an adapter and both monitors work on DVI and VGA.. so thats not the problem!
i turn of my computer.. plug in both.. turn it on..
the vga monitor works.. i go to properties>setting and turn on the other monitor.. click aply ofc
nothing happens.. the DVI monitor doesnt go on.. tried some resolution problem etc.. turn on stretching..
go into nvidia control panel.. change some settings there.. nothing..
bassicly i did everything
ok but heres the weird part!
when i turn of computer.. and only connect the VDI or DVI.. i think its DVI .. the monitor works..
i already said that xD.. BUT.. when i connect the VGA monitor..
here it comes ^^
windows doesnt see it in properties.. BUT when i go nvidia control panel.. theres one option
CLONE MODE!..
i enable that.. AND IT WORKS!...
but its the only option.. theres no dual view or stretch or anything..
its really confusing me O.O
when i connect both and turn it on.. windows sees both.. all the options are there.. but the second monitor never goes on.. no matter what i do...
could it be theres some interference?
i cleaned my disk today.. and installed a fresh new XP..
my videcard is : nvidia geforce 8600 gs
ask me any question if your confused!.. i really want this sorted.. or atleast get an asnwer why this is happening
thanks in advance!
here it comes ^^
CLONE MODE!..
thanks in advance!
