wireless card help
Forum Wireless Networking : Wireless General Discussions - wireless card help
my friend has a dell inspiron 8600 notebook i need to know what would a good wireless network card be for under 50 $.
side note - will be connecting to a t1 line.
Sponsored Links
Proxim silver or gold. You should be able to get one for under 50.
Reply to kwebb
- 0 +
I had bad experiences with the proxim gold a/b/g. I found that the reassociation time is really bad. This only applies if you are moving around while connected to the AP, so if you plan to stay at approximately the same location while connected then there is no problem.
My suggestion would be a Cisco, but they usually are more expensive than 50$. Second choice a NetGear which should be in your price range.
In ancient times they had no statistics so they had to fall back on lies
Reply to goloap
Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > wireless card help
There are 1079 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
