Sign-in / Sign-up
Motherboard problem
  • Asus
  • Motherboards
November 9, 2010 3:17:24 AM
Hello, i have asus motherboard, i have problem, cpu fan running mb green light showing but display is not showing, what problem in mb
More about : motherboard problem
a c 216 Ĉ ASUS
a c 425 V Motherboard
November 9, 2010 3:25:21 AM
More often than not .....None. Most 1st, 2nd , 3rd time builder scare themselves with this :)
I'll bet the monitor is set to receive a signal from a port different than the one you are connected to. Use the monitor OSD to select HDMI if ya used HDMI cable for example. If it's set to something else, no display.
m
l
