Hello everyone!
I'm attempting to set up a WEP connection for the computers in my home. The connection is functioning fine for the wired computer, and is being broadcast and in range for my other wireless ones. However, when I connect to the network it appears to work - I have the green bars in the upper right corner, it tells me upon double clicking that I will disconnect, the little star is there in the right corner, etc. Next to the star says 'not connected' and I can't use the internet. I know that I need to change something, especially since is doesn't ask for my WEP key... but what do I need to fix?? Please reply ASAP!
Thanks!
Thanks!
