Solved
Silence parts for for I7 860
Last response: in Systems
I want to build pc with mb GigaByte P55A-UD3 and I7 860.
need help for choosing good parts which are also silence as possible:
1. a good cooler (CoolerCooler Master Hyper 212 Plus?) .
2. CASE (Antec 900 Two?)
3. HD in the range 1tb -- 2tb
4. Power supply (Antec TP-750 ?)
5. video card (HD5670 ?)
6. ram 4G DDR3
thanks
Shaul
More about : silence parts for 860
Today I am not in games . maybe I will be in 3D and simulation.
I like to open lots of app in same time.
Even if I do not sure what I will do , I have a very good feeling that I will have midrange strong computer (even if I will not use its power!) I am willing to pay for this feeling.
I am sure it will look very strange, but I do not have limit to my budget.
On the other side I do not want to buy the most top PC because I like the point of balance between money & performance.
this lead me to choose I7 860 and MB follow after it.
OS will be win7 .
yes I need also KB & Mouse-- wireless is not important but I want to prevent as much as possible the pain in my hands and fingers.
thank you
Niklas_13 said:
whats this PC going to be used for ?
whats your budget
whats your monitors rez
do you need a OS KB Mouse
I forget to answer :o S today is XP PRO .my mointor is DELL 2408WFP rez 1920 on 1200
Related ressources
Ok this is what i would do
Sony Optiarc 24X DVD/CD Rewritable Drive Black SATA Model AD-7240S-0B - OEM
Item #: N82E16827118030
Return Policy: Limited Replacement Only Return Policy
Protect Your Investment (expand for options)
Service Net Replacement Extended Warranty Plan
The product will be replaced and shipped directly to you at no charge(more info)
• 1 year: $6.99
• 2 year: $11.99
$24.99
Antec Nine Hundred Two Black Steel ATX Mid Tower Computer Case - Retail
Item #: N82E16811129058
-$30.00 Instant
$139.95
$109.95
Seagate Barracuda 7200.12 ST31000528AS 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Item #: N82E16822148433
Return Policy: Standard Return Policy
$89.99
XFX HD-577X-ZNFC Radeon HD 5770 1GB 128-bit DDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card - Retail
Item #: N82E16814150462
Return Policy: VGA Replacement Only Return Policy
-$10.00 Instant
$164.99
$154.99
Antec TruePower New TP-550 550W Continuous Power ATX12V V2.3 / EPS12V V2.91 SLI Certified CrossFire Ready 80 PLUS BRONZE ... - Retail
Item #: N82E16817371020
-$30.00 Instant
$20.00 Mail-in Rebate
$119.99
$89.99
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL7D-4GBRH - Retail
Item #: N82E16820231276
Return Policy: Memory Standard Return Policy
-$5.00 Instant
$114.99
$109.99
GIGABYTE GA-P55A-UD3 LGA 1156 Intel P55 SATA 6Gb/s USB 3.0 ATX Intel Motherboard - Retail
Item #: N82E16813128412
-$15.00 Instant
$139.99
$124.99
Intel Core i7-860 Lynnfield 2.8GHz LGA 1156 95W Quad-Core Processor Model BX80605I7860 - Retail
Item #: N82E16819115214
Return Policy: CPU Replacement Only Return Policy
-$10.00 Instant
$289.99
$279.99
Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders - OEM
Item #: N82E16832116754
Return Policy: Software Return Policy
$104.99
Subtotal: $1,089.87
kb,mouse,speakers, get whatever you like that feel and sound the best to you
If you want to OC get this HSF http://www.newegg.com/Product/Product.aspx?Item=N82E168...
and this RAM in place of the other ram http://www.newegg.com/Product/Product.aspx?Item=N82E168...
If you want the opition to xfire get
mobo http://www.newegg.com/Product/Product.aspx?Item=N82E168... in place of the other
PSU http://www.newegg.com/Product/Product.aspx?Item=N82E168... in place of the other
6. ram 4G DDR3
thanks
Shaul
Hi Shaul,
Take a look at the Noctua NH-U12 SEP, great cooler, ultra quiet (comes with 2 low noise adaptors), super quality.
I know they are more expensive, but i have bought 2 of these to use with i7 860 systems and using the ultra low noise adaptors I
still get very low idle temps.
Regards keith263
keith263 said:
Hi Shaul,
Regards keith263
Is this the part name . NH-U12 SEP ?
I do not find it the word "SEP"
See my configuration (signature).
It is also a silent one if you replace my proc fan.
Zalman CNPS9700 is loud on high rpm but it is a silent one with the lowest speed.
Just replace that and it is quite.
BTW : I put my PC just beside me. Just beside my keyboard and mouse on the table.
The distance between my ear to my PC is less than 50cm. I can almost hear nothing.
Take a look at the Mugen 2 Rev. B. Its much larger than the 212+, because its mostly a passive cooler.The fan only spins at 1200 RPM max, and all 4 sides can mount fans. Just beware of its large size and make sure u get revision B. Its a dream cooler if you have the room.
it support LGA1156 socket?
It is indeed very good but it looks as if it does not support LGA1156 socket.
Best solution
Sorry, my mistake that should have been Noctua NH-U12P SE2.
Regards keith263
Regards keith263
Have any link to reviews that measure and compare the noise level of Noctua NH-U12P SE2 ?
Ask the community
