K kuni Distinguished Oct 23, 2009 33 0 18,530 May 21, 2010 #1 I've got a p183 and am thinking about installing an intake fan or two. Can the fan control switches (on the back of the case) be used to control both the intake and output fans? E
ssddx Titan May 27, 2009 17,054 5 74,965 May 21, 2010 #2 Check the maximum watt-output for the controller against the watt rating for the fans. If the draw is less than the maximum then it should work fine. Check your specs and post your findings. Upvote 0 Downvote
