Hey, guys.......I have a few questions regarding my hardware, custom build's cooling options, and fan placement.
First off, I'll give you the hardware. I've tried to stay on a pretty low budget thus far. (If you guys have any suggestions or critiques, don't hold back)
CPU: AMD Phenom II x3 720 BE
Mother Board: MSI 770-G45 (ATX)
Power Supply: hec X-Power Pro 650 650W
HDD: Samsung Spinpoint 3.5" 7200RPM 1TB
Graphics Card: XFX HD-577X-ZNFC Radeon HD 5770
RAM: G-Skill 2x2 GB DDR3 1600
Fan+HS: Arctic Cooling Freezer 64 Pro 92mm
I plan a doing a bit of gaming, but nothing extremely intensive. I'll probably end up OC'ing the Phenom. On SketchUp7, I have all of the hardware built into a compact 9" x 12" x 9" custom case that I plan on making out of plexiglass.
The size isn't set in stone. I've basically disregarded all cords/connectors at the moment. I'll probably end up pulling the front out a bit to give room to the PSU.
Here's the rough model.
Front1:
Front2:
Back1:
Back2:
I have the CPU fan pulling from the heatsink with an exhaust fan directly behind to get the hot air out as quickly as possible. My HDD will be suspended, anchored on the power supply and side of the case. A 120mm exhaust fan is taking hot air out of the back top of the case. Right now, I don't know if air circulation will be sufficient to keep all of the components cool.
You can see that I almost have a wall built up with the graphics card, DVD/CD drive, and power supply......I'm wondering if this will create significant problems with strange air streams, resulting in dead spots.
What do you guys think about this setup?
Front1:
Front2:
Back1:
Back2:
