OK i had a money problem and lost $400 that was going to be put on this PC so now im trying to build a Gaming PC for $1,000. Also i will be adding more to this PC down the road i want to have CF 5870s ill add a DVD/cd burner, Right now i have one that external i can use. also i will probably add a blue ray 3 monitors and who knows what other stuff.
I am using the Haf 932 all ready bought and painted Black and Green.
Ill find a monitor from a friend or somthing till i can get some money 4 a nice one.
Just looking for some ideas to make it cheaper and not loose any performance maybe someone knows of some deals i missed or somthing?
So here is what i got.
AMD Phenom II X4 955
GIGABYTE GA-790FXTA-UD5
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.345266
XFX HD-587X-ZNFC Radeon HD 5870
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150476
Antec TruePower New TP-750
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371025
G.SKILL Ripjaws Series 4GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231276
SAMSUNG Spinpoint F3 HD253GJ 250GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152226
Microsoft Windows 7 Home
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116754
