CPU fan speed
My computer keeps rebooting for no reason. I installed a new video card and later I realized it was the PSU that was causing it to restart and then updated the PSU. Life was smooth until now and the PC keeps rebooting again. I went into the BIOS and noted that
CPU Fan Speed: 0 RPM
System Fan Speed: 3245 RPM
CPU Temp: 41 C
System Temp: 30 C
Is there something here that I am missing?
7 answers Last reply
More about speed
  1. List your specs please.
    41°C should be fine for any CPU... It could be a second dodgy PSU.
  2. CPU Fan Speed = 0 is not okay. Your CPU 41 C temp may just be at the start but since the CPU Fan does not spin, the CPU temp will rise the longer the PC is on... But it should shut down as far as I know... not reboot...
    Make sure your CPU FAN is spinning. Check that it the CPU fan is connected to the CPU FAN header...
  3. +1 to what randomkid said. You need to ensure that your CPU fan speed does increase as you use your computer otherwise you will experience overheating issues. A visual check can also tell you if the fan is rotating.
  4. thank you for your responses.
    Below are the specs:
    AMD Sempron 3400 Processor
    1.5GB RAM
    XP Pro Service Pack 3
    GE Force 8600 GT Graphics card
    ECS 761GX-M754 Mother board
    Visual check seems fine...it does seem to be rotating...when I opened that up, the bottom was brown so that I added some paste on there making sure not to touch that by hand. the display showing "CPU Fan: 0 RPM" doesn't mean the fan is not working does it? So Can I just let it go.
  5. CPU Fan: 0rpm is a problem. Are you sure you plug the CPU fan connector to the motherboard CPU Fan header correctly? Can you take pictures?
    And you clarify where you added some paste? Do you mean between the processor and the heatsink? Also check if the heatsink is clear of dust. Even if the fan is spinning but it the heatsink is dirty it is bound to heat up since the heat can not dissipate out of dusty heatsink.
  6. It sounds like the motherboard's onboard sensor is malfunctioning, maybe from poor voltage from previous psu.
    Thank you once again for your replies. I will post the pictures shortly as I don't have the computer with me right away, but the CPU fan sure was rotating. I did add some paste between the processor and the heat sink and the heat sink was cleaned with a compressed air can. I think pictures would explain the best and will get them posted as soon as I can.
CPUs Graphics Cards Computer
