Problems - New Build
Last response: in Systems
Hello,
I built 2 machines with the same specs and Im running into the same problem with both of them.
They both freeze for no apparent reason, after trying everything I can think of I am convinced its a RAM problem.
Specs:
MS Windows 7 Ultimate 64-bit
AMD Athlon II X4 620
4.0GB Dual-Channel DDR3 @ 1333MHz 9-9-9-24
ASUSTeK Computer INC. M4A785TD-V EVO
My BIOS is V02.61 which I believe is the latest (Asus site is crap, cant access it... but from what I read, that's it).
According to CPU-Z my memory is running at 669.6Mhz.
Type: DDR3
Size 4096 MB
Channels: Dual
NB Frequency: 2008.9
DDR Frequency: 669.6 Mhz
FSB:RAM: 3:10
9-9-9-24
Bank Cycle Time: 33 Clocks
Command Rate 1T
I guess the question is, am I onto something?
Do I have RAM issues (As I suspect)?
Im somewhat of a newb on this and have spent HOURS trying to find the answers with no success.
Thanks
More about : problems build
Ask the community
