Hi guys
Great stickies you guys have up in the forum, been reading through them and have learned a lot. I plan on switching from an high-end air cooled rig to a custom water-cooled one sometime over the next couple of months (depending on work/vacation, budget etc :lol: ). but first all the talk about cooling fluids got me curious.
I'll qualify this question by saying that I'm a trained physical biochemist specializing in nano-particle design but also dabble a bit in chemistry and basic engineering. I can't go into details about what I do due to legal reasons, but I'll say that it is in no way related (at least for now) to computer components or cooling, this is purely a hobby. now between stuff I've read on TH and overclockers etc, it seems like the consensus is that distilled water + copper sulfate (PTNuke) +silver (kill coil), and that the more additives you add, the more often you'll need to flush/rinse/refill your loop due to corrosion, clogs, erosion etc etc.
so in theory, if I say flush my loop with pure ethanol, fill my loop with de-ionized water (more using the process to kill any possible living thing in the water rather than getting rid of ions, I know the water will strip ions from my blocks etc), UV and/or radiation sterilize my filled loop, would I then have a maintenance free water-cooling loop?
My thinking is that since the loop is filled with clean stuff, say I go out of my way to find copper only components for the whole loop, then all i'll have is a few copper ions in my water which will never cause me any problem right?
P.S. the reason I want to do this is that I actually have a really hectic work/life schedule and cannot guarantee a semi-regular maintenance cycle. However, I am willing to even take a few days off work and spend a few extra bucks to reduce the maintenance cycle to say every 2-3 years, which will coincide with my upgrade cycle
Thanks in advance!
Thanks in advance!
