Well I put together a list of parts to build a dual loop system wanted to get some feedback before I place the order all fittings are 1/2" ID Koolance Compression Fittings did I grab any bad items or items that are not worth the scrap metal they are made out of?
Pump
EK Mountable Dual Loop Top - Black Acetal - Dual Reservoir w/ Dual D5 Variant Pumps Installed
•Pump Top Style: 5.25" Mountable D5 Dual Loop Top - White Acetal5.25" Mountable D5 Dual Loop Top - White Acetal
The power of two D5 pumps..... yup that is right TWO D5 or MCP655 in in two separate loops is now easy to set up with the EK 5.25" Mountable D5 Dual Loop Top. Multiple mounting options include 5.25" bay mounting stand alone and Multi-option reservoir hook up! You can have either a single block loop with a 9 block loop this combination of two of...
•Reservoir Style: 2 x RES X2 - Tube 60/200mm2 x RES X2 - Tube 60/200mm
Multioption tube for EK-Multioption RES X2 . This is a replacement tube for the 60mm in diameter X2 Series EK reservoirs. It is 200mm in length. ($22.00)
•Pump Style: 2 x Alphacool VPP Variable Speed2 x Alphacool VPP Variable Speed
The Alphacool VPP655 Variable Speed Pump - Bare Bones Single Edition is just the pump. Why buy a full D5 / MCP655 Series pump when you can just get the guts of the unit alone. Fits directly into bay reservoirs made for D5 MCP655 Series and this pump is ideal for PC and other electronics water cooling. The DC pump is equipped with an electronic...
•Top Style: 2 x EK-Multioption RES X2 - Top2 x EK-Multioption RES X2 - Top
EK-Multioption RES X2 - TOP W/thread is an additional single port top made of high quality POM Acetal for your favorite EK-Multioption RES X2 series.
•Select G 1/4" Fittings (Qty. 4): 1/2" ID Koolance Compression Fittings1/2" ID Koolance Compression Fittings
The Koolance 1/2" (13mm) ID G1/4 Threaded Nozzles Pair is one pair of rotational 1/2" (13mm) ID G1/4 threaded nozzles for Koolance components with replaceable nozzles. Nickel-plated brass with compression fitting and gasket. ($25.98)
GPU Block
2x Aquacomputer aquagraFX HD 7970 Full Coverage Liquid Cooling Block - Copper Version (23534)
•Select G 1/4" Fittings (Qty. 2): 1/2" ID Koolance Compression Fittings1/2" ID Koolance Compression Fittings
The Koolance 1/2" (13mm) ID G1/4 Threaded Nozzles Pair is one pair of rotational 1/2" (13mm) ID G1/4 threaded nozzles for Koolance components with replaceable nozzles. Nickel-plated brass with compression fitting and gasket. ($12.99)
Radi
2x Koolance Triple 120MM Copper High Flow
CPU Block
EK Supremacy Uni CPU Block Full Copper
Tubing
Tygon Silver antimicrobial
Bling
PrimoChill anti Kink VU Coil UV GREEN
Pump
GPU Block
Radi
CPU Block
Tubing
Bling
