Port forwarding problem
Hi,
I'm trying to forward the ports from my router to my laptop necessary to play World of Warcraft. The ports are 3724 TCP / UDP and 1119 TCP. I put all three of these ports into my router's port forwarding interface. I then used portforward.com's port checker to check them. The 3724 ports are open and fine, but the 1119 TCP port says it is still closed.
Router: Motorola WR850G
OS: Windows Vista
Does anyone know why this would be?
1 answer Last reply
More about port forwarding problem
  1. Have you turned off the firewall on Vista?
    Side note: I am assuming you have hardset the IP on your computer so it won't change.
Routers World Of Warcraft TCP/IP Port Forwarding Networking
