With the kind help from you guys on here I managed to pick out a pump and a top/reservoir that I'd be using:
D5 motor only and ek xres csq 140 ml.
Mounting of the res/top:
Extremely fail picture of my loop made in paint:
I fail to see how it would work with the outlets/inlets. Could anyone enlighten me as to what fittings i would need? Also from the cpu to the 240mm rad in the roof: would a 45 or a 90 degrees fitting be best?
Finally: how would I go about adding a T-line? I suppose it would be just before the pump?
/wc noob out.
/wc noob out.
