So I have been looking at the radiator
120mm
http://www.amazon.com/XSPC-EX120-Radiator/dp/B0067LW8HY/ref=sr_1_3?s=electronics&ie=UTF8&qid=1358740446&sr=1-3&keywords=XSPC+RX120
240mm
http://www.amazon.com/XSPC-RX240-Performance-Radiator-5060175580788/dp/B0028ACALW/ref=sr_1_2?s=electronics&ie=UTF8&qid=1358740091&sr=1-2&keywords=XSPC+RX120
I was wondering(I am cooling a i5-3570k will overclock as far as possible) if there is a big diffrence between the temps I would get adn if it is worth the extra money... also i will be using these to cool it(if there is a better fan then please, recommend it.
thank you for the help
120mm
240mm
