What Muffin is trying to tell you is Watercooling is the way, unless you want to spend the extra time developing a Tec plate loop then regular W/c is the best option,
Real W/c, not an allinone like the sealed corsair units, a pump, reservoir, tubing fittings and blocks,
If you don't want to spend the time learning then W/c probably isn't for you,
In the sticky there are some links for allinone coolers as well as regular W/c gear but only you can decide how much time/effort you are willing to put into this.
Moto
