Sudden XP problem
Last response: in Video Games
Anonymous
August 12, 2004 5:15:55 PM
Archived from groups: alt.games.thief-dark-project (More info?)
I have been running T1, T2, and FM's on XP for quite a while now, but all of
a sudden all these now crash when I run them. They load fine, but when I
move the game crashes by locking up the whole system. I must reboot.
It started when I tried to play the FM Konkurrant, but no one else on the
TTLG forum seems to have a problem after loading this FM.
All other software and games, including T3, run just fine, so it must be a
Thief-XP problem. Has someone had this problem and solved it?
Thanks
More about : sudden problem
Anonymous
August 14, 2004 2:02:29 AM
On Thu, 12 Aug 2004 13:15:55 -0400, "John Webb" <jwebb7@cox.net>
>Thanks
I had similar problems after installing T3. After installing T3, I
couldn't get Darlloader/FM's or T1 and T2 to work right. My PC would
freeze at the instant the mission was about to begin. I managed to
fix the problem by applying a "fixed" thief.exe file I got from
thecircle.com. This exe fix was for nvidia cards so it may not work
for you. The filename was thieffixedg.exe but I had to rename it to
just thief.exe in order for it to work properly. When I left it named
thieffixedg.exe I would get prompted to insert CD2. Hope this helps;
hope you get it working.
Anonymous
August 14, 2004 10:51:59 AM
"gums" <noreply@all.com> wrote in message
news:5tdqh0tp6s4v1blq797r6cn7ra8djk13qr@4ax.com...
of
a
> >Thanks
I have an ATI card, but I tried the "fixed" theif.exe file anyway. It had no
effect one way or the other. I kind of doubt that T3 brought the problem
about because it loads into its own folder, separate from the Thief2 folder.
