How much power is needed for 4 graphics card?
This is my Build and I have these parts but I dont know how much power I need and what is the best power supply..any info would be greatly appreciated
EVGA classified 3way (will not be using sli)
i7 930
corsair dominator 6gb 1600 (will clock to 1333)
(4)evga 260 core 216 (wont overclock)
x-25m ssd
wd caviar black 1TB 7200rpm
win 7 pro 64 bit
Prolimatech Megahalems CPU Cooler
ThermalTake ArmorPlus Case
9 answers Last reply
More about power needed graphics card
  1. Why do you need 4 GPUs? Most boards cannot physically fit 4 GPUs with dual slot coolers.
    You would probably need a good 1kW PSU to power that, maybe even something a bit stronger. What ever you are doing that needs 4 GTX260s you can probably do a bit better with different cards and not need nearly as much power.
  2. I am using it for trading with eight monitors plus I use it as my entertainment center. I dont have cable. I watch movies, television, stream bloomberg and cnbc on the internet so I wanted to build something that is fast, graphically stable and will last for some years...
    Four graphic cards was cheaper than 2 that supported 4 monitors .. The only others was the gtx250 or the FX 380 I read a few posts and fiqured I would go with the gtx 260 because it was a little better
  3. yea but will the graphics for streaming movies, and television be the same
  4. Wow didnt know that..what about the stream processors..does that make a big difference
  5. what would be a good quiet power supply
  6. I will be using the gtx260s
  7. This is my build...already have the parts
  8. sorry...forgot to paste it
    i7 930
    corsair dominator
    x-25m ssd
    win 7 pro 64 bit
  9. For running multiple monitors with the kind of work you do you should look into Matrox graphic solutions. Matrox is the king of multi monitor setups for your type of application they actually just came out with a card that can drive 8 monitor with 1 card. Now the money saved on power consumption and the big PSU that you will need to run all those cards would really make the Matrox card worth looking at.
    Check out what they have to offer.
    http://www.matrox.com/graphics/en/products/graphics_cards/m_series/
Power Supplies Graphics Cards Power Components
