J jackneedshelp Honorable Nov 23, 2012 3 0 10,510 Nov 24, 2012 #1 All of a sudden, I have no sound on my computer and the device manager says that I have no sound device. Any ideas?
PhilFrisbie Splendid Apr 22, 2006 6,472 3 26,465 Nov 24, 2012 #2 Have you been into the BIOS settings? If so, go back in and make sure you did not disable the sound hardware. If not, try reloading the sound driver. Upvote 0 Downvote
west7 Honorable Nov 23, 2012 115 0 10,710 Nov 24, 2012 #3 try reinstall the sound driver Upvote 0 Downvote
J jackneedshelp Honorable Nov 23, 2012 3 0 10,510 Nov 29, 2012 #4 PhilFrisbie : Have you been into the BIOS settings? If so, go back in and make sure you did not disable the sound hardware. If not, try reloading the sound driver. Thanks for the advice - I haven't been able to access the BIOS settings, but I'll keep trying. Upvote 0 Downvote
J jackneedshelp Honorable Nov 23, 2012 3 0 10,510 Nov 29, 2012 #5 west7 : try reinstall the sound driver I've done that, but no success. Thanks for the advice, tho. Upvote 0 Downvote
