G Guest Guest May 26, 2010 #1 Which rating power supply is needed for core i5 build and overclocking to 3.4 ghz?
welshmousepk Distinguished Sep 12, 2009 3,437 0 21,160 May 26, 2010 #2 The processor alone drains hardly any power. we need to know what else is on your system, most importantly the GPU. Upvote 0 Downvote
G Guest Guest May 26, 2010 #3 I want to build this setup Core i5 750 Asus P7P55D HD HIS 5850 320 GB SEGATE HARD DRIVE 4 GB CORSAIR XMS 3 Upvote 0 Downvote
welshmousepk Distinguished Sep 12, 2009 3,437 0 21,160 May 26, 2010 #4 for that, i would recommend a good 550w PSU, such as the corsair vx550. http://www.newegg.com/Product/Product.aspx?Item=N82E16817139004&Tpk=corsair%20550 corsair PSUs are some of the best, high quality and efficient. with an excellent warranty. and a 550w should be plenty for your system. Upvote 0 Downvote
shubham1401 Distinguished Apr 21, 2009 2,754 0 20,960 May 26, 2010 #5 10 more bucks will give you a 650TX: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005 Upvote 0 Downvote
G Guest Guest May 26, 2010 #6 But i think that will cross my budget of $1000.I have to get a casing and dvd rom too.I think i will go with 550 watt! Upvote 0 Downvote
