What power supply do I need
Hello,
I have a Zotac Geforce GTX 260 and I do not think i have enough power supply inputs!
The graphics card needs 4 Power Supply Inputs but my power supply only has 4 in which three are being used by the rest of my PC
What Power Supply would I need to run my entire PC and the new graphics Card?
Thanks for all the Help
Andy
2 answers Last reply
More about what power supply need
  1. What power supply do you have now?
    The recommended power supply would be 500W and have +12 Volt current rating of 36 Amps.
    Thats from an EVGA recommendation for that type of GTX 260 video card.
    http://www.evga.com/products/moreInfo.asp?pn=896-P3-1255-AR&family=GeForce%20200%20Series%20Family
    An example of a PSU that meets those requirements is Antec EarthWatts EA-500D which has 37Amps of +12V.
  2. You need two 6 pin 75 watt PCIE connectors to power the GPU. I think you are talking about the adapter that turns two molex 4 pin connectors into 1 6 pin. I do not recommend doing this if you value your system go get a quality PSU.
    Antec EA500
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817371035
    or
    CORSAIR CMPSU-550VX 550W 69.99 after rebate
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139004
    I would go with the corsair unit.
Power Supplies Graphics Cards Geforce Components Product
