Hi guys,
My motherboard specs on memory:
4X240-pin DIMM sockets. Memory capacity 8GB
Support Dual Channel DDR2 533/ 667/ 800/ 1066 (by AM2+ CPU)
I have already used up 3 slots with the following RAMS.
1) KVR400X64C3A/512
2 & 3) KVR667D2N5/1G
I think I should take out the 512 RAM . Correct me if I am wrong ?
I am looking to upgrade to at least 4GB RAM. I am wondering if it is ok for me to buy "DDR2 800Mhz CL6 2GB" ?
Will it caus any conflict as my two other RAM that I wished to remain inside is of 667Mhz speed and of 1GB, not 2GB.
Since my motherboard supports Dual Channel, will installing only 3 RAMS lower the performance ?
My main concern is:
1) Will mixing the speed caus under performance ?
2) Will mixing the capacity of each RAM caus any issue ?
3) For my case, is Even number of RAM better than Odd number since it is Dual Channel supported ?
1) KVR400X64C3A/512
My main concern is:
