Hi.
I have followed this tutorial to OC my CPU:
http://www.overclock.net/t/1198504/complete-overclocking-guide-sandy-bridge-ivy-bridge-asrock-edition
My speccs are in my sig.
The only difference between the tutorial and what i am doing is that I dropped my LLC to level 5(0% compensation) because level 3 was getting me high vcore and high temps even at turbo offset +0,004v.
I was now at turbo off +0,051v and it was running stable for one hour with prime95 blend test but I had 1 core going 83ºC.The other cores were ~77ºC save for core #3 that was at 71ºC max.
Saturday I left the PC running on LLC 5 and +0,020v turbo for 5 hour and got no BSOD or prime 95/explorer/drivers/etc crashes,now it crashes fast at that offset.
I found that my cpu behaviour was odd and send my computer to the store so they figure it out.It is not normal for i5-3570k to read 40ºc at bios after being turned off for 10h.It was also odd to see temps going 80% off the time going ~72ºC max and then jump to high ~70's then drop down again.My room temps is very low,the floor is made off granite and just standing on it makes my legs go cold.Also the air coming from the ehxaust fans was cold.I am only using my fans at 9v through the fan controller on the phantom 410 to keep noise low.The only time hot air came out of the ehxaust fans was after the 5 hour prime 95 and even then it was barely above normal room temp.
To note that my vcore was at about 1,256 to 1,288 although it was 1,270 90% of the time.
What can I do to stablize it at lower voltage?I am guessing I could get it better if my vcore wanst going up and down on lower vcores so LLC seems that it could help.
Furthermore IBT at standard passed well with vcore much lower than this,even at extreme it wouldnt crash,just generate too much heat.
Anyone can lend me a hand or find me a decent OC guide?I have no idea what to try besides clearing CMOS setting the mult to 45 and work with fixed vcore which I was hoping not to do because I dont want to spend unnecessary electricity and shorten the cpu lifespan.
Any help will be greatly appreciated.
Thanks in advance!
EDIT:Seems my sig is not appearing so here are my speccs:
I5-3570k @ 3.4ghz(OCing soon)//Noctua D14 HSF//ASRock Z77 Extreme 4//NZXT Phantom 410 case//8Gb G.Skill Sniper Low Voltage//MSI GTX670 PE-OC//XFX XXX 750W//HDD Seagate Barracuda 2TB 7200rpm// 2 x Coolink Swif2 120mm//3 x Antec TwoCool 140mm//2x NZXT FN120RB
Thanks in advance!
