sticky
TEC/Peltier CPU Chilled Water Cooling - Page 4
  • Overclocking
  • Water Cooling
  • Product
  • Below Ambient Cooling
  • CPUs
  • Cooling
a b K Overclocking
a b à CPUs
September 6, 2013 6:16:14 AM
I would like everyone to know that I am duplicating this set-up Ryan has because I saw it in action myself last year. It does work and work well I might add.
I will be adding pictures once I have it up and running. ;)
a c 249 K Overclocking
a c 110 à CPUs
September 6, 2013 6:31:12 AM
ArthurH, I've been defending this cooling solution for so long it sometimes seems like I'm all alone shouting to the world, even though it's been in operation over 9 months, but you have personally witnessed this cooling in operation, and I appreciate your confirmation!
Thank You! Ry
a c 110 à CPUs
September 7, 2013 6:42:11 AM
3770K NOT DELIDDED 45c max core temperature at 4.5ghz, with this cooling! :)
3770K NOT DELIDDED 69c max core temperature at 5.0GHZ, with this cooling! :)
September 8, 2013 5:09:44 AM
4Ryan6 said:
I do live in the states in South Carolina, the original peltier link did not work, but this one does and that peltier is fine and a good price too.
As to whether the motor voltage controller will work? IDK
I control the cold output with the TRUEs cooling fan, I do not allow my computer to stay on all the time, only when I use it, so it's only drawing power to run the peltier or peltiers when it's running, so I do not need the voltage controller.
For your information gathering, my reservoir is not insulated to the point of long term cold retention, it's insulated for short term cold retention, meaning after it's been turned off for 12 hours the water temperature inside the reservoir is still below, but very close to ambient.
The reason for this is it avoids any cold booting problems and once the machine is powered the water temperature begins to drop, and continues to drop until it reaches and equalization point usually 7c ~ 8c below ambient room temperature.
A traditional radiator loop starts at ambient and increases heat in the above ambient zone until it reaches an equalization point above ambient, whereas mine starts close to the same but goes in the opposite direction to below ambient.
In the beginning I did play with controlling the voltage, but it caused the peltier to stall, getting what you can use from the peltier constantly, will require a constant voltage, at least in the way I am using the peltiers output, keeping it in a range of constant cold output.
I know some of this doesn't make any logical sense, the peltier is what it is, and sometimes reacts peculiarly, but you can milk what you want from it and enjoy the benefits, as long as you discover how to get what you want from it, without it stalling.
Once I discovered it's cold output could be controlled with the cooling fan on the Thermalright TRUE, there was no further reason to experiment with voltage regulation, so if you are going that route, please share what you discover.
And that, is exactly, why I've been asking you all these questions :)  little pearls of knowledge which would have otherwise cost me several hundred pounds when I came to needlessly insulate this mineral oil case, and then several more when I cold started my CPU. I would never have thought about it had you not said.
Still gonna play with controlling the peltier, not that I have the PC on all the time, just because I'd like to have the control over its function. Thinking of marketing these things if it works, so I want to play with the option of an adjustable set-up. Ie, currently I have a processor and single GPU. All in all, thats about 240w dumped into the oil. Add to that the other bits such as RAM, other assorted MOBO chips and general ambient absorbtion through the sides, I've estimated about 300w overall I need to shift out. This is all at max capacity. Say I was to throw another GPU in there. Nobody is going to want a system in which a small change such as an additional GPU leads to a total overhaul of their cooling system. Admittedly, a GPU upgrade carries with it about £150 worth of additional waterblock, but I'd like a system with a little knob on the side, which reads "MAX POWER" or goes from 1-11. At least that way, you can tune the peltier to your system over a couple of days, then leave it at that opperating setting, then, a year or so later when you add a second GPU or overclock something, you can click up a notch and still stay atop the problem.
I'm really tempted to get the 400w monster from that Ebay seller as a result of this thinking.
Cheers though! You've been fantastic, I'm putting it all together and I'll let you know how it goes :)
a c 110 à CPUs
September 8, 2013 5:13:13 AM
Great! Looking forward to your results! :)
a b K Overclocking
a b à CPUs
October 1, 2013 2:04:07 PM
LOL Ryan Why you scaring everyone away! lol
a c 110 à CPUs
October 1, 2013 4:08:57 PM
a b K Overclocking
a b à CPUs
October 3, 2013 4:51:01 AM
hello was reading his threed and thought that i would place my two cents worth noticed that a 400W TEC might be in this build some time in the future. I have been playing around now for some time with the TEC's that i have and have noticed that the 250W TEC produced great results with only the CPU or one video card the 400W got colder but was hard to control I found that 4 100W TEC's gave even better results with two componits connected to the system and it is easy to maintain stable temps. well this is what i noticed maybe you will have better results. good luck
a c 110 à CPUs
October 3, 2013 6:36:34 AM
Interesting!
Would you care to elaborate further on your tests including, peltier sizes IE, mm x mm, voltage, amperage, and peltier specs of all the peltiers you've tested?
Would you also elaborate on how you tested 4 100W TECs to arrive at your conclusion?
a b K Overclocking
a b à CPUs
October 3, 2013 7:13:30 AM
Ok the TEC's are 254W 18amp 16V 50mm X 50mm, 435W 30amp 16V 50mm X 50mm, 100W 10amp 16V 40mm X 40mm, my set up currently, is much like yours, water blocks on one side and air coolers on the other, i am working on incorperating the EXP little rads to shrink the build, but regardless, there is a few places online that do match these findings as well, I found the info while serching for a way to control the larger TEC, but if you are determined, give it a try, you are a pretty smart guy, you might figure out how to controle that beast.
a c 110 à CPUs
October 3, 2013 7:39:54 AM
Do you have a purchasing link to that 435w 50 x 50?
a b K Overclocking
a b à CPUs
October 3, 2013 7:46:52 AM
got it on ebay about 5 months ago it is not for sale there now. but the company is still there. do you want that?
a c 110 à CPUs
October 3, 2013 8:04:23 AM
I found a 400w but it was a 62mm x 62mm 24v, not really what I would experiment with.
Now that 2nd link you provided is a possibility! :)
a b K Overclocking
a b à CPUs
October 3, 2013 8:12:46 AM
the top link is a 50mm the bottom is a 50mm as well edit
a c 110 à CPUs
October 3, 2013 8:15:44 AM
toolmaker_03 said:
the top link is a 50mm the bottom is a 62mm
Check again, both links are 50mm x 50mm
November 24, 2013 2:01:30 PM
4Ryan6 said:
kauedg said:
I received my TECs two days ago. One day ago I fried a lousy PSU while testing. Good, one extra fan, extra wires and connectors! Got -22C tho... Waiting for the appropriate PSU (12V ~ 20A) to arrive now.
What are the peltier specs and size?
Here I am 3 months later. These are my TECs:
1x
15.3V ~ 97W
2x
12V ~ 72W
All are 4cm x 4cm x 0.3cm.
Right now I have a setup running on a Celeron I bought only for testing. I have made a peltier cooler just like the one in your setup, using the 92W piece, just to test how much it can cool the water (no processor in the loop). It's been running for the last 30 minutes and the water reached 22C, with no insulation whatsoever on the system.
It's a weak TEC. I will order one of that you use in your system (http://www.frozencpu.com/products/2408/exp-01/245W_Pott...) and see how it goes... My peltier PSU broke and I will have to buy another. This 92W runs from the 12V rail from the ATX PSU and it runs good, not warming up the wires. Here are some pics...
November 24, 2013 2:23:31 PM
Right now I'm looking for "stronger" 40mm x 40mm TECs. This one just won't do it.
a c 110 à CPUs
November 25, 2013 2:47:39 AM
What you linked is exactly what I am using and is very demanding on your power supply so make sure you get the power to power it from either the 8pin M/B connector or a PCI-E connector as they are 14g output wires, the molex cabling is only 18g wire, and that power draw will destroy them.
November 25, 2013 7:30:23 PM
What kind of PSU do you suggest to power the peltiers? Do you know another peltier module with higher Qc than this one?
a c 110 à CPUs
November 26, 2013 1:45:35 AM
It needs to be a single 12v rail, with the amperage load handling capability only 2/3rds met by the peltiers, and only run the peltiers on the power supply nothing else.
Load example if the power supply can handle a 62a total load, then only run 40a of peltiers, could be 2 20a peltiers.
That way the power supply can cruise under the load never kicking into high cooling mode, if you max the power supplies amperage load you'll shorten it's lifespan and force it to run maxxed out.
Peltiers are a constant load, never forget that!
You need a good quality power supply like PCP&C, Corsair, Silverstone, Seasonic, Enermax, Etc.
a c 110 à CPUs
November 26, 2013 5:25:01 AM
toolmaker_03 said:
http://www.ebay.com/itm/Thermoelectric-Peltier-Refriger...
Thought that you would be interested in this unit looks like I have seen this some ware before. Maybe you have inspired someone to give it a try.
Wouldn't surprise me this thread is linked from a lot of other websites, once the true capabilities of this cooling are fully discovered by others, it should catch like wildfire!
a b K Overclocking
a b à CPUs
November 26, 2013 5:45:20 AM
I have seen a few of them come and go over the years but your setup seems to be more functional or it works better than the production models I have seen thus far.
I am still working on mine, I have almost finished the radiators they are now configured into a single module or loop. The case loop is as well I have that hardware down to a single loop for everything. The only thing left for me now is to build the TEC module for the rig, and connect it to the system.
November 26, 2013 1:31:00 PM
Somewhere earlier in this thread I said about an add-on Peltier module for already assembled watercoolers... =)
a b K Overclocking
a b à CPUs
November 26, 2013 1:45:44 PM
Really because that is what I am currently making, that way if I need to work on the TEC unit or add upgrades to it I can remove the TEC module and attach the radiator module to the system and keep playing games. I am finishing the radiator module now for the system, just a few more upgrades and it will be done. I will have pics of the system as each module gets compleated.
a c 110 à CPUs
November 27, 2013 2:12:49 AM
OK for the record I've covered in this thread that using a peltier and a radiator in the same loop basically cancels each other, if you're after cooling below ambient performance it is a bad idea.
Using a peltier attached to a radiator does not work and many have tried that approach and come away disappointed.
a c 110 à CPUs
December 2, 2013 1:59:56 AM
Present cooling setup passes 1 year of operation, News at 11! :)
a c 110 à CPUs
December 3, 2013 2:56:34 AM
It's really amazing to be able to run my 3770K at 5ghz 24/7 and the CPU not delidded, many wonder why even do it but the desktop and application response is amazing at 5ghz, it tends to seriously spoil you.
Once you get spoiled by the response you don't want to go back, it's kinda like comparing the performance of a Volkswagen Beetle to a Chevy Corvette, until you actually drive the two, you just don't know, you can imagine what you want, but once you know, well there it is!
I'm only running on one peltier energized unless I'm gaming, then I energize the 2nd unit and that comfortably drops my water temperature about 10c below ambient room temperature, which is gaming cruising for a 5ghz clock.
I am not running hyper threading on the 3770K, for the applications I am running it has proved to do more harm than good, there is almost zero of the games I play it could possibly help, and it actually cuts the audio/video encoding frames per second performance in half, somewhere in the vicinity of 650fps cut down to around 240fps, and that's totally unacceptable.
In all my testing the only advantage I've seen hyper threading gain is in Futuremark benchmarks, there it does show score improvement but that doesn't make it useable when it takes more CPU voltage which equals more heat to dissipate, to stabilize the CPU running hyper threading, for no other gains.
Passing as I said above 1 year in operation with this present setup, with zero problems so far!
My best to everyone! Ryan
a c 110 à CPUs
December 3, 2013 3:29:12 AM
Your CPU-Z validation still stands as one of the best anyone achieved back in the day, overclocking the Q9550 was a serious challenge going past 4ghz, there were only a handful that came near that success overclocking a core 2 quad.
You should be proud of what you accomplished! Ry
December 8, 2013 8:43:31 PM
Hello there, long time lurker here. (Since ~2004)
Apologies for arriving late to the party but here's some random musing.
I have a theory why direct peltier mounting to the CPU will basically guarantee a "fail".
1) Peltiers don't have actual "cold" & "hot" sides.
The way you pump the power in is what determines the cold & hot side.
2) Peltiers are also generators that convert heat differentials into electricity.
3) One would pump electricity to the cooler in a way that cools the CPU side while cooling the "hot" side of the peltier.
4) CPUs get very hot, very quickly. (Hot enough to cook actually http://www.youtube.com/watch?v=7uBNCN6v_gk)
Putting those together makes it easy to see why it fails:
A) System starts at ambient temp. (Both "hot" & "cold" sides are at equal temps)
You set up the rig & turn on the system.
Peltier is now cooling the CPU.
B) CPU quickly generates massive amount of heat.
Peltier now sees the CPU as the hot side & the coolant side as the cold side.
C) Peltier starts generating a large electrical current >>counter<< to the power you're attempting to pump in = terribad efficiency while CPU continues to heat up further going against the input.
4Ryan6's set up circumvents this issue by working with the peltier rather than against it by actually having the cold & hot side in the way we want it rather than flipping it with a direct CPU mounted setup. (By allowing the water to dissipate the heat to a level the peltiers can manage, thus minimizing the counter current).
Or in other words:
4Ryan6's setup = "Full-Power Super Saiyan"
http://www.youtube.com/watch?v=xGsUN4do5mE
Direct CPU mount = "Ultra Super Saiyan"
http://www.youtube.com/watch?v=0J_u97yaJEQ
a c 110 à CPUs
December 9, 2013 3:48:52 AM
@ a123b
Interesting theory!
:lol:  Frying bologna on a CPU, that was interesting!
Most all that direct mount peltiers to a CPU run independent power supplies to supply the max voltage the peltier can handle which normally is at least 15v ~ 16v DC and some up to 24v DC, with the peltier powered separately from the PC itself.
In those circumstances all they have to do is power the peltier before the PC is actually powered up, then the peltier is producing enough cold way below ambient to override the CPUs heat, then they're back to the condensation and ice forming, that they insulate the motherboard against.
Your theory is actually exactly what happens with a direct mount when both are powered at the same time from an ambient temperature, but the direct supplied voltage will overcome the generated voltage effect rather quickly, but there will be a cold build up stall taking place, that's probably why they power the peltier separately.
Very Interesting!
Thank You for your input!
December 9, 2013 2:28:49 PM
Guys, I'm doing some research and I'm setting up something amazing. On top of Ryan's great solution I'm setting up an Arduino controller to read reservoir's water level, temperature and water flow. This way it's possible to achieve a fully auto controlled system. Here are some things that are possible:
- reservoir's water temperature;
--> Automatically make the second peltier module kick-in;
--> Warn when the water hits a defined temperature with the two peltier modules working;
- reservoir's water level;
--> Warn when the water level is low;
- water flow;
--> Warn when the water flow has stopped (eventually turning off the computer when the reservoir's water reaches like 30C, for example, so you have time to save stuff);
- peltiers' temperature;
- cooler fans' speed;
--> Change their speed to reach a desired peltier cold side temperature;
--> Warn if they stop working;
... and many more.
I'm making some tests with an arduino simulator until my modules aren't delivered and I start using the real thing.
a c 110 à CPUs
December 9, 2013 10:55:54 PM
@ kauedg, I am definitely interested in your results!
a b K Overclocking
a b à CPUs
December 12, 2013 8:43:47 AM
Finally I have my cooling system up and running. This is basically a clone of Ryans cooling system. The important components, not the case. It took 30 minutes to go from ambient to 10C with my i7 2700k CPU @ 5.0GHz. It idles @ 17.5C and during IBT run @ 55C avg.
This is a shot of my "Cooling Tower" using an old Antec case I modified for this purpose.
This is a shot of my PC showing the cooling lines going into the back of my case via a notch I cut out so when the side panel is removed the lines can be moved around for easier service. That suggestion came from Ryan as well and I really like it. :)
The next two shots are of both my PC and cooling tower as I have them set-up and running.
I have not gamed yet with this set-up but think it will do just fine. I will report back how my gaming session went when I get a chance. :D
December 12, 2013 9:31:21 AM
Ryan have you experimented with smaller reservoir size? It seems too big sometimes I check the pictures again.
Also, is the use of CM 212 necessary or was just something you had around?
a b K Overclocking
a b à CPUs
December 12, 2013 2:40:41 PM
I am posting some more details about my set-up with pics.
This is a shot of my Swiftec CPU water block black top modified with a dremel tool for more water flow.
This is a close up of my peltier between a 1/8th" alum. block, Thermalright Venomous X-rt CPU cooler and modified Swiftec water block.
This is a shot of the whole peltier assembly.
This is a close up of my lapped alum. block. Lapped on both sides.
More to follow.
a b K Overclocking
a b à CPUs
December 12, 2013 2:51:00 PM
This side panel had a clear window in it. I removed that and using the same mounting hardware for the window installed "Hardware Cloth".
This next shot shows my modified case before wiring and insulation.
This is the back of my modified case. Although you can not see it too well the cooling units are offset so I would have room to reach and adjust the pump without having to take the side panel off.
A closer peek at my pumps speed regulator.
a b K Overclocking
a b à CPUs
December 13, 2013 7:03:39 AM
I got a request to show some more detailed shots.
These first two shots are with my removable plug removed.
This next shot shows a mounting bracket I made from 1/2" angle alum. to mount that assembly on and to my case.
This shot is not easy to make out but I used 1/2" U channel alum. to make a mount for my pump.
Still have not gamed enough to give accurate temp readings. I will post them once I have them. :)
a c 110 à CPUs
December 14, 2013 6:30:15 AM
Nice Arthur, That's an interesting reservoir mount, can you explain what we cannot see in the pictures as to how you mounted it?
I know you've got a lot of testing to do, but in your opinion is your results so far meeting your expectations?
Please share everything you learn, It's very exciting to me another is running this cooling, Thank You for having the guts to take the plunge! Ry
a c 110 à CPUs
December 14, 2013 6:43:56 AM
At the beginning of the thread is a link to the entire journey that led to this setup, and I have experimented with a smaller reservoir size down to a dual bay XSPC reservoir, which was not an adequate cold storage collection reservoir, that's why I made my own using 4" PVC pipe, and insulated it.
The heat pipe cooler is not a CM 212, as it will not handle the heat load to properly cool the peltiers being used, the heat pipe coolers I am running are Thermalright TRUEs, which are still available today at.
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=46_450_504&products_id=26116
And all of this is covered in the threads, either this one or the linked thread, this thread is to share exactly what works should you decide to duplicate this cooling solution yourself.
a b K Overclocking
a b à CPUs
December 14, 2013 8:25:52 AM
First question. No.
Just joking. :)  I had a 4" coupler that I glued to the 4" pipe then cut it off near where the pipe is, giving me double the normal thickness to use to drill holes in it without compromising the pipe in any way.
This system so far meets my expectations completely. I am very happy with the results I have been able to achieve thus far.
I have to add that Ryan really nailed this in his explanations of what works and what did not. I followed this to the letter buying the recommended parts he referred to in his thread and they work as stated. This is a fully reproducible cooling solution for those wishing to have a below ambient cooling solution that does not require extreme insulation of any other part of your computer, excluding of course the cooling lines going to your CPU water block. I did mount things some what differently and used a different case but the concept is "exactly" like his.
December 14, 2013 3:08:20 PM
Thanks, I just lost the counting of how many times I've read the post. I'm following your setup and I'll make some measures with the hw I got (pelts' sweet spot, water flow speed and so on).
Sorry for asking about stuff already there, sometimes I miss a topic or another. I started to learn Arduino boards (just got it to work with Eclipse) and I think I'm starting a thread of my own, to document the work. By monday or tuesday I'll buy some parts to build a 3-pin fan controller (to control the CoolerMaster Blizzard T2 I have) and a temperature probe. The probe will read the water temperature and increase/decrease fan speed to maintain a certain temp level. Hope it works.
In the near future I'll make a Java program wich communicates with the Arduino board, showing the readings and allowing to configure the system's parameters. It's going to be awesome =D
December 14, 2013 3:09:50 PM
First problems that raised: this cooling solution takes a lot of space (another tower just for it) and the price... it's really expensive the get all the parts.
a c 110 à CPUs
December 15, 2013 7:26:26 AM
A below ambient cooling solution is definitely going to cost you more than the investment an elaborate radiator cooling system that can barely match ambient room temperature will actually cost you.
The cheapest below ambient is simply a drink cooler with ice, pump, tubing, and a CPU water block.
Even that below ambient cooling solution requires a certain amount of space for it to be setup.
I never claimed this peltier cooling was a cheap cooling solution, it is guaranteed to allow you to run below ambient, but it is up to the user as to whether it is worth the expense to them or not.
a c 110 à CPUs
December 15, 2013 7:58:08 AM
kauedg said:
Have you considered using other heatsinks? Like this little monster:
http://www.ebay.com/itm/Thermalright-Macho-120-Rev-A-CP...
I have used other heat sinks but not the one you linked, will it work?, I don't know, you'd have to try it yourself and report your results with it.
The parts assembly of this thread are guaranteed to work for you, and the setup has been in daily operation over a year now.
Now that another Toms Hardware member has built his on setup from the design and has confirmed it works, it is no longer my word against the world, and soon others will duplicate the setup themselves and discover it all works as well.
After all the trial and error experimenting, once I arrived at a successful cooling setup, I stopped experimenting and decided to run the system for longevity and dependability and so far so good.
a b K Overclocking
a b à CPUs
December 15, 2013 6:48:27 PM
I just finished playing Crysis for a little over an hour @ a temporary clock of 5.08GHz.
Started at a mim of 19.75C CPU (according to Real Temp) and reservoir was reading 12.5C. My max temp was 40C according to Real Temp. I went back to 5.0GHz as I did not care for the 1.44Vc needed to run @ 5.08GHz with stability. :)
My bad on OC. Meant 5.08GHz. My BLCK is 99.76 default and I leave it there.
a c 110 à CPUs
December 16, 2013 2:48:32 AM
arthurh said:
I just finished playing Crysis for a little over an hour @ a temporary clock of 5.88GHz.
Started at a mim of 19.75C CPU (according to Real Temp) and reservoir was reading 12.5C. My max temp was 40C according to Real Temp. I went back to 5.0GHz as I did not care for the 1.44Vc needed to run @ 5.88GHz with stability. :)
If you're going to claim 5.88ghz stable overclock lets see some CPU-Z validation, and some completed IBT and benchmark scores to ensure total stability, and why worry about 1.44v when the Sandy Bridge max tested Intel voltage was 1.520v, you are still within 1.520v.
You should post an overclock like that in the Intel Overclocking Club thread, following all the requirements.
Now that you have this cooling in operation you need to handle what it can do with wisdom or else get ready to replace your hardware. :)
Once you damage the CPU Arthur, there is no undoing it, there's good reason my setup has lasted over a year without damaging my 2700K and 3770K.
Be Careful Sir! Ry
a c 110 à CPUs
December 16, 2013 3:47:22 AM
Thank You for that clarification I can now go pull my head out of the toilet! :)
    • First
    • Previous
    • 4 / 6
    • 5
    • 6
    • More pages
    • Next
    • Newest
      • 1
      • 2
      • 3
      • 4 / 6
      • 5
      • 6
