http://www.newegg.com/Product/Product.aspx?Item=N82E16835426020&Tpk=gelid%20gc%20extreme
is this a good compound to apply to a HDT cooler and does it perform very well. benchmarks say it does but i want some personal opinions.
i would also like to replace the stock thermal compound on my GTX 470 and maybe the thermal tape on the VRAM modules
So would applying this non-corrosive paste that doesn't conduct electricity on the VRAM modules which would be replacing the stock thermal tape be a good idea? or is this a nono?
i would like to do this because i do not wish to purchase some more stuff... i.e. thermal tape, if i can just use some thermal compound that i already will be buying.
Thanks all for your replies.
