Disc reader / burner and Gamer pc help
Last response: in Components
May 27, 2010 3:57:49 AM
Hi there, just wondering if all disc readers / burners work in all computers.
Also could you tell me if all these components work with each other and is a decent gaming pc:
Windows 7
Case: Antec Two Hundred v2 - $59.99
Power Supply: Corsair 750W - $89.99
Processor: Phenom II X4 965 Black Edition - $179.99
Graphics Card: XFX Radeon HD 5770 XXX Edition - $169.99
Motherboard: ASUS M4N75TD - $99.99
Memory: Crucial 4GB DDR3 1333 RAM - $99.99
Optical Drive: Lite-On Black 24x DVD-R/RW SATA Reader/Burner - $20 (i have one from my current pc i don't know if it will work though)
Hardrive?
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Hard Drive: Hitachi 1TB 7200rpm 32MB cache SATA - $79.99
Thanks for replying and for your info!
May 27, 2010 11:17:41 AM
Um....With your build:
Get the X4 955 instead of the 965 as it is a waste of money.
Your PSU is way overkill, is there a reason for this? Such as going to upgrade to a high end graphics card soon? Otherwise go for a 500W or 450W one or if you plan on Crossfiring it then go for a 600W one.
Samsung Spinpoint is the best. Get it.
And yes your optical drive will work fine.
Hope that helps.
m
l
