Archived from groups: comp.sys.laptops (More info?)
Hi,
I have a Dell Latitude CPx which has an annoying problem with the left ctrl
and shift keys. Before they do what they're supposed to do, I have to press
them twice. Or when I keep them pressed, they will work on the second
character. This laptop has BIOS version A05; I have another laptop of the
same model, which doesn't behave that weird, but has bios version A03. Is
there a solution to this? It's not a keyboard going bad or a bad contact as
the behaviour is consistent.
"Jeroen" <sink@null.dev> wrote in message
news:4135f015$0$14941$e4fe514c@news.xs4all.nl...
> Hi,
ctrl
press
as
Check that you don't have "Sticky Keys" set up. This is one of the
Microsoft Accessibility options for people with disabilities.
In NT: Control Panel\Accessibility Options\Keyboard
Should be similar in XP etc.
