Yes No
Ads
Tom's Hardware > Forum > CPU & Components > CPUs > Using lemon juice to remove old thermal compound??
Forum CPU & Components : CPUs Using lemon juice to remove old thermal compound??
Hi,
I have just ordered a corsair H50-1 liquid cooler. Now I have realised I don't have any of the thermal compound remover to clean my processor up before I attach the H50.
A friend has told me that lemon juice is perfect for removing thermal compound and that compound remover is just a rip off.
Does anybody here use lemon juice?
Is it okay to use lemon juice?
Is there anything else that can be used to remove thermal compound?
Thanks,
Reply to CheckMate2010
I dont know abt cleaning using lemon juice,Use a good clean cotton cloth to clean it if you dont have remover!
Reply to Aneesh@4GHz
Yeah liquid contact with something as vital as a CPU is never really a good idea, most thermal compound scratches off anyway.
------------------------------ Phenom II 965 @ stock 3.4GHz|| ASUS M3N-HT 780a MoBo|| 4GB Corsair XMS2 8500-C5C RAM|| 500GB Seagate Barracuda HDD|| XFX nVidia GTX 295|| OCZ GameXstream 700W PSU||
Reply to Shadowsken
- 1 +
Just run to the drug store and pick up a bottle of isopropyl alcohol, the higher the purity the better.
I have some thermal compound remover that I use from time to time. Each set comes with two bottles, one you apply and soak in first, and another you use for the final clean. I don't know if they're a rip-off, but they get the job done very nicely.
I don't think the lemon juice idea is a very good one though. You're going to get a lot of water and sugar everywhere. Lemon juice is mostly water and sugar. Besides, you still have to go out and buy the lemons or the bottle of juice. Might as well pick up the isopropyl and then you have something for cleaning your computer, and topically cleaning your wounds.
Reply to Arethel
- 0 +
If you are careful lighter fluid works well also...:)
------------------------------ When you obsess on your enemy,,
You become The Enemy...
Reply to dokk2
Thanks for the replies everyone!
I think i'll probably go get some isopropyl alcohol or the propper stuff. I do have lemon juice in the fridge but I didn't much like the idea of putting it on my processor which is why I asked for your opinions. Doesn't look like any of you have even heard of it so it's probably not a common practice to use lemon juice to clean processors!!
I won't take the risk!!!!
------------------------------ intel core i7 860; asus p7p55d; 4GB Corsair 1600MHz C8 RAM; nVidia GeForce 8600 GT; corsair 650W PSU; Cooler Master CM690 Dominator Case;
- 0 +
Lemon juice is a no no. It is very acidic. I use Isoproyl acohol mostly, but the store bought stuff makes it easier and faster.
Reply to daship
LOL - I think the OP meant lemon juice, not lemonade :P.
However I have heard that ketchup makes a good silver polish :D
Reply to fazers_on_stun
- 0 +
I always use 91% isopropyll alcohol. I would not use lemon juice; even if the acidity cleaned off the old thermal paste, it would no doubt leave a residue. Lighter fluid also leaves a residue, as does WD-40; those things shouldn't be used.
After removing the old paste, apply a small rice-grain-sized dab of new paste to the top of your CPU, and use your finger in a plastic bag to spread it evenly over the surface.
------------------------------ Save your money. Step outside the incessant churn.
Reply to jtt283
There are 1841 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Case with filters. Recommendations?
By al360ex, 4 hours ago:
Then I'd go with one of these cases. If you choose the HAF 932 Advanced Edition, you...
Best offers
Top experts
