I recently made my first build with these specs:
Case: COOLER MASTER HAF 922
Mobo: ASRock 880G EXTREME3 AM3 AMD 880G SATA 6Gb/s USB 3.0 HDMI ATX AMD Motherboard
CPU: AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Socket AM3 125W Quad-Core Processor HDZ955FBGMBOX
GPU: GIGABYTE GV-R687D5-1GD-B Radeon HD 6870 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP
PSU: XFX P1-650X-CAG9 650W ATX12V 2.2 / ESP12V 2.91 SLI
RAM: Mushkin Enhanced Blackline 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model 996781
I am also re-using my HDD and DVD from my Dell XPS. (Had to reformat the HDD with Win7 in order for it to work with new build.)
CD/DVD: HG5894D VEG622Z SCSI
HDD: WDC WD2500JS-75NCB3 Serial ATA SATA-300
Once the new OS was installed (and all related drivers, excluding dell driver for DVD, keyboard/mouse), everything worked fine. Start-up was slow (upwards of a minute), but I wasn't too worried about that.
Then everything went to hell. Upon start-up, several processes failed to initialize, different memory references couldn't be read, and blue screens abounded. To the point that the system blue screened before the OS fully loaded. I reformatted and reinstalled everything. Same result - worked for a couple days, then crapped out.
Several errors were memory related, so I though the problem was the RAM. I moved the 2 sticks to the other slots, and everything worked normally (immediately after blue screens upon startup before changing slots). I ran mem diagnostics and no problems were found. So I thought the issue was the mem slots on the mobo. To prove that, I moved the sticks back to the original slots, but everything STILL worked. I ran mem diagnostics and no errors were found.
EDIT: Failed to mention that in the midst of the above issues, checkdisk ran a couple times on start-up and a TON of indexes, etc were corrupted/removed/fixed, etc.
Once again, the system worked for a couple days, but now it is starting to crap out again - blue screens (although not as many as before), mainly just system freezing and apps stalling. Problems seem to abound when I play Crysis (the only game I have on the PC right now).
I now wonder if the problem is my HDD, but possible culprits could be the mem slots on the Mobo and/or the RAM.
What are your thoughts?
