Now that I have a separate graphics card, I'd like to see how far I can push my APU. With its GPU not running, it stays plenty cool, so I know I can go higher. Using the Asus AI auto-tuner, I'm at 4.4 Ghz or so (44 multiplier and 102 frequency) but if I go into the bios & change the multiplier to 45, it fails all of the prime95 tests. I know I need to give the cpu a little more umph, but not sure what to change. There are a bewildering set of choices on my asus board. Found some screenshots here, about halfway down the page:
http://www.bjorn3d.com/2012/11/asus-f2a85-v-pro/
Any suggestions would be helpful. I only understand a few of the choices; there are all kinds of options for voltages, frequencies and current capabilities, and I'm scared I'll change the wrong thing and burn something up...
Thanks!
-Mark
Thanks!
-Mark
