V vlevans Honorable Nov 27, 2012 2 0 10,510 Nov 28, 2012 #1 windows will not respond to misconfig when i enter it in the run programmes, says windows can,t find it, so can,t access alaunch, need to do this, was working fine s few days ago, please advise simple solution, am not that comp savvy, thank you
Solution ex_bubblehead Nov 28, 2012 msconfig is one of the first things that gets disabled by virus/malware. Download and run a full scan with Malwarebytes ( www.malwarebytes.org ).
TenPc Honorable Jul 11, 2012 2,471 1 11,960 Nov 28, 2012 #2 Enter in Run Command CMD enter key then in the "DOS" dialog, msconfig hit Enter key. It is not a good idea to mess around with the msconfig, it is only for checking errors and problem solving on certain startup features and programs. You may be best to disable start up options in programs and use the "Stop Service" feature in Adminstrative tools for best and safer results. Upvote 0 Downvote
ex_bubblehead Titan Moderator Aug 24, 2012 16,249 1,518 87,240 Nov 28, 2012 Solution #3 msconfig is one of the first things that gets disabled by virus/malware. Download and run a full scan with Malwarebytes ( www.malwarebytes.org ). Upvote 0 Downvote Solution
