Hey, I'm a Junior at AC Reynolds High in NC and we are starting out Junior Project this semester. To graduate you have to pass your Senior Project and you are allowed to build off of your Junior Project
So for my Junior/Senior Project I'm going to build a computer.
I'd like to keep the price under $1000 not including a monitor.
Here is the list so far:
Cooler Master Elite 310 Case w/ Window
AMD Athlon II X4 Propus 630 2.8ghz Quad Core
MSI 790FX-GD70 AM3 Motherboard
or
MSI NF980-G65 AM3 Motherboard
This is where I'm stuck... I don't know if I want to go Nvidia or ATI for the Graphics.
I'm leaning toward Nvidia because they support CUDA which from what I know helps in Video/Photo editing.
If I go Nvidia I'm going to use the discrete graphics and save up for a better GPU.
If I go ATI I'm going to have to get a GPU right off the bat and I'll have to get a mid-low range GPU to stay within my budget.
No matter which one I go with I want to in time upgrade to an SLI or Crossfire set-up.
So the first question of many is do you think I should go with Nvidia or ATI?
Thanks in advance,
Nicholas
or
Thanks in advance,
Nicholas
