Yesterday I tried to uninstall a program called my privet folder. It had some problems but I uninstalled it with Revo uninstaller. Today I noticed in my system try the safely remove usb device Icon had disappeared. I went to customize the notification and the to see if it was hidden or inactive. It shows as active but the icon is replaced by a folder. I tried to do a system restore but got this error.
System Restore
System Restore is not able to protect your computer. Please restart your computer, and then run System Restore again.
I went to services.msc to make sure System Restore service was started. When I clicked start it gave me the error.
Could not start the System Restore Service service on Local Computer.
Error 1114: A dynamic link library (DLL) initialization routine failed.
I went to system properties then to system restore and clicked turn off system restore. when I clicked ok I get the error.
System Restore encountered an error trying to enable/disable one or more drives. Please restart your machine and try again.
Later I noticed that my system time had changed to military time. When I go to control panel the regional and language icon is gone.
I went to my system 32 folder and tried to open int.cpl but nothing happens.
Now my desktop background changed by itself and when I try to change it nothing happens.
I can't figure out the correlation between all these problems but they are driving me crazy.
I have Windows xp pro 32 bit.
Any help would be great.
System Restore
